Performance analysis
We've reviewed our test kit to include a hotter-running graphics card and a slightly higher CPU overclock as the cases we'd tested since changing the test kit recently hadn't resulted in enough variation. The Kublai handled out overclocked Core i5-4690K well, though, thanks to the generous amount of mesh and reasonably powerful front 120mm fan situated so it directs a proportion of its airflow straight at the CPU cooler. Compared to the Phanteks EVOLV ATX, it's clear that the KL05's mesh front is important in allowing its single 120mm fan to draw air into the case - in both the EVOLV ATX and NZXT Noctis 450, the front fans don't have such an easy time, with the EVOLV ATX especially, sporting quite an obstructed front section.
SilverStone Kublai KL05 Review SilverStone Kublai KL05 Review - Performance analysis and Conclusion SilverStone Kublai KL05 Review SilverStone Kublai KL05 Review - Performance analysis and Conclusion
The GPU delta T was a slightly different story. There was far less of a difference between the three cases we've tested so far, but it's clear that having an intake fan at the bottom of the case at the front aids the GPU - with the KL05, its single fan is mounted in the middle of the front panel, so is of limited use and is also blocked by the drive mounts at the level of the GPU and below. Even so, there's plenty of cooling on offer, although you'll obviously see better results removing the drive caddies and dropping another 120mm fan into the lower front fan mount.
Conclusion
The Kublai KL05-W offers a heck of a lot for the cash. If you're after a budget water-cooling case or one that can swallow the vast majority of current all-in-one liquid coolers with no modding and plenty of room to spare, it scores top marks. It's not a looker, and is rather basic in some areas, but at less than £60 it still represents extremely good value.
The cooling results are encouraging too. Despite only being equipped with a single 120mm fan, and an intake at that, the large and extremely porous nature of the case with its mass of mesh panels helps it deal with the heat of a high-end overclocked air-cooled system quite easily. Add in a rear and roof fan, and you'll have a very solid case indeed.
  • Cooling
    25 / 30
  • Features
    15 / 20
  • Design
    25 / 30
  • Value
    19 / 20
Score guide
Where to buy
Overall 84%
